RCU Forums - View Single Post - CMP BF109F BUILDING THREAD
Old 12-25-2012 | 02:57 PM
  #1909
Sharpeye22's Avatar
Sharpeye22
Default RE: CMP BF109F BUILDING THREAD
Well the Sierra retracts with the Down and Locked conversion is out due to cost.
Sierra retracts $250
Down and Locked concersion $350
$600 is to much for me for a set of retracts.
the reason I was leaning toward this option was I wanted the struts built into the retracts instead of attached with a 5mm pin and set screws.
I guess I will opt for the E-flight 120s or the Lados. Both of which I have used in the past. That means adding the struts via the pin and set screw method.<br type="_moz" />
