RE: Amp draw , battery direct to motor vs thru ESC
I made no changes! Neither the prop nor direction changes, both measurements were
made with a fully charged 1700 mah nimh battery. The connectors are Deans so I could not change the direction. The motor is reverse timed and that is the direction for both tests. The prop is a Gunther 5 x 4.5
Thanks for the replies.
Woodduck
