ORIGINAL: skeeter_ca
Prior to gluing can the hinge be installed and removed as needed during building of the model and to check for proper alignment or does this widen to hole to much?
Is the hinge pin installed mostly flush with the surface or does it stick out some so as to pivot the control surface around the edge?
skeeter
It does in fact widen the hole, but if you use the Gorilla glue it just is not a problem.
Bob
