RCU Forums - View Single Post - Hanger 9 AT-6
Old 09-13-2003 | 06:34 PM
Bumstead's Avatar
Bumstead
Default RE: Hanger 9 AT-6
Everything went back togeather great. Glad that it broke away clean.
Re-epoxyed everything, mounted the engine.
One thing, for you out there thinking of using a TT .91RFS, the tank mount as-is
puts the tank way above the carb, read siphoning.
What I did was make a new base for the tank with some
ply planks, enlarged the hole in the firewall and lowered the tank about
an inch. Can't go too much or you will interfere with the wing top.
Cusioned everything with EPS foam.
I keep meaning to post some pix but still converting files.
New name for the AT-6...Battle Hardened!
