RCU Forums - View Single Post - Is this normal behavior?
Old 12-28-2012 | 05:05 AM
RMB677
Default RE: Is this normal behavior?
The take off to the left is normal due to blade/engine torque. I'm also a relative biginner and it has taken me quite a while to hover under control, still working on nose in hover. I've found it best to increase the throttle to where the heli shows a lean to the left and then compensate with the right stick while increasing the speed till the heli lifts off. Good luck.
