RE: Larger Revolver
Has anyone come across this while assembling the Revolver 70?
Excuse me if this has been mentioned before, I couldn't find it.
I put the aileron servo in the right wing, connected it to the aileron and the aileron control horn mounted in the middle of the Plywood reinforcement on the aileron.
Working on the left wing just before drilling the hole in the aileron for the horn, I noticed it was barely on the plywood.
I measured everything and found that the cutout for the servo bay on the Left wing was a half inch farther inboard than the right wing. I'm sure it won't affect the flying, except maybe having to add weight for lateral CG, but it is annoying that they cut out the servo bay wrong on the left wing.
Is this a common problem?
