RCU Forums - View Single Post - Electric Choke?
Old 12-28-2012 | 07:36 PM
vertical grimmace's Avatar
vertical grimmace
Default RE: Electric Choke?
You can operate a switch with a servo, but not really sure that helps you here or what it would be for. The ignition kills do not need a servo to operate.
Now that your servo is going the right way, you can use a Y harness there. I would use a manual choke cable so you can prime your engine to start it.
I would also recommend an optic kill for your ignition. Then you can kill your engine, and if you have a radio issue, the optic kill will auto shut down your engine.
