RCU Forums - View Single Post - Comp ARF BAE Hawk build thread
Old 12-29-2012 | 03:03 AM
  #989
fireblade5437's Avatar
fireblade5437
Default RE: Comp ARF BAE Hawk build thread
Stig
How much is the carbon tube out by? mm?
Mine was tight I just 'polished' with 1000 wet/dry paper
Some pics of the fittings I made for end of carbon tube also the servo mount I made out out FG board as the wooden ones in my kit.... well I would not use them for what they were intended for...
Also made bushes for the purple servo arms (Phosphor bronze) so there was zero play in clevis. Grey glue is Hysol 9461 same tear strength as 9462 but works out a lot cheaper I buy it in tubes of 200ml (400ml total)
Loctite® Hysol® 9461 A&B 400ml (451233) 1 £36.84 £7.37 £44.21
Sub Total: £36.84
Delivery: £3.50
VAT: £8.07
Total: £48.41
From site:
Description
Loctite® Hysol® 9461 A&B is a toughened, 2K-Epoxy adhesive, suitable for applications requiring gap filling and high peel strength. Ideal for bonding dissimilar substrates like GRP, SMC and composites.
This product requires: Loctite® Dual Cartridge Dispenser
Specifications
• Non-sag paste
• Heat accelerated (4 min. @ 120°C)
• High peel strength
Typical Properties
• Mix ratio by volume: 1:1
• Mix ratio by weight: 100:100
• Working life: 40 min.
• Fixture time: 240 min.
• Colour: Grey
• Viscosity: 270 Pa.s
• Shear strength (GBMS): 24 N/mm²
• Peel strength (GBMS): 10.0 N/mm
• Operating temperature: up to 100°C
Description
Code
Price
(Inc. VAT )
Est. Delivery
50ml
451231
£13.72
In stock
400ml
451233
£46.67
1 week
Alan
ID:	1834481   Click image for larger version
ID:	1834482   Click image for larger version
