RE: Stick 75 problem
If the controls are working properly, it is probably bound OK. BUT you may not have enough battery capacity to allow full throttle. That will make the BEC turn on and stop the motor. You may also have to set the throw on the throttle 0-100%. Really need more info on what it is.
