Hi, i am rearanging and upgrading my Shockwave 55, re-glasing the hull (original is to thin!) and re-installing theengin supportstringers and installing an Arrow SharkSR512 Stingray Drivestigner. I am using the stock Zenoha 230 (for now) and I was wondering what the distance between the transom and the clutch on the motor should be so I can use a standard 1/4 Flex Shaft? I am not sure i can use the same mounting holes for the engine as the original since I'm changing the drive? I will most likley install a newArrow Shark non-springV2 clutch and collet.
Any suggestions on the correct distance for my mounting bracket would be much appriciated?
