RCU Forums - View Single Post - Newb needs help with tornado s30
Old 12-30-2012 | 10:40 AM
Mikeydank
Default RE: Newb needs help with tornado s30
Ok. Something's not right. I had unscrewed the idle screw too far just playing with it. I understand there's a notch in the barrel inside the carb. I got it back in the notch, but when I turn it to the right it keeps the barrel from being able to turn. Also, when the idle screw is backed out to where the throttle will turn, the LSN moves freely in and out, which I'm guessing shouldn't happen. There's two holes in the barrel, one on the top one on the bottom. I'm guessing the top is the idle port and the bottom is the throttle hole. Sorry I'm asking so many questions I'm just trying to figure out why this is happening because the idle screw didn't cause the barrel to lock up like this before and I can't seem to figure out why this is happening.
