ORIGINAL: A.T.
ORIGINAL: dmaaero As per post #2 that worked pefect for flaprons, could you please add a simple way to achive 3 second delay to flaprons?
Update to post #2,
''Depending on what you select, the radio will automatically optimize the functions for your choices.
In other words, if you select a wing type without flaps, there will be no flap function control.
Note options in that model memories programming.</p>
1. Select ''System Settings'' > ''MDLType''> Wing = ''2AILE''.
User will note Ch1 AILE:J1 Ch5 AIL2:J1 is preset when checked on the Channel menu.
2. Enter Model menu 2/2 select ''FLAP CON'' > (defaults to LS). If a switch is preferred, select ''NULL'' > select which switch you desire (e.g. ''G'').
3. Return one screen, and set amount of flap control required for each of the two servos, say reduce from 100% (no movement) to 60% - 70% for both. User can also mix in ''ELEV: 0%'', increasing the ''0'' as desired.
NB: When using two aileron servos in flapperon mode, servo speed can not be adjusted for the flaps without also impacting on the speed at which the ailerons move (slow ailerons not recommended). If slow flap speed required, then use default setting with Flaps assigned to the Left Slider (or transfer to Right Slider) and increase/decrease flaps at required speed manually.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
</p>
