RE: Air Leaks
if a stethoscope is not working then you might have a defect cylinder /damage o-ring.
Meaning that there is a leak between the two apartments and from there you loose pressure to the environment.
Take the pliers and pinch your retract lines one of the time.When you hear the leak to stop, remove and take apart the cylinder,your o-rings there might need replacement
my 2c
