RE: Aurora 9 flaperon set up
I can select LS for the flaps in the channel menu but then the flaps will only operate if the Flap Con menu is inhibited. If I select NULL for flaps in the channel menu then I can activate Flap Con and get everything working with elevator mix on switch A to G, no slider option.
