RCU Forums - View Single Post - Paint Question
Old 12-31-2012 | 06:37 AM
TomCrump's Avatar
TomCrump
Default RE: Paint Question
ORIGINAL: OldScaleGuy
Interesting. Tom, what ratio are you using, paint to hardener to acetone?
Steve, the can says 1 can to a quart. That's what I do, although I usually mix a pint of paint and a half can of hardener.
I don't mix it to the acetone, but to the paint.
I add the hardener to the paint, and then thin with acetone.
No set ratio of paint to acetone. I thin to the consistancy of milk. I probably start at 2 parts paint, and one acetone. I test spray, and add more solvent,if necessary. It could easily end up as a 1:1 mix.
