RCU Forums - View Single Post - Illusion Build
Old 12-31-2012 | 07:43 AM
  #33
edp's Avatar
edp
Default RE: Illusion Build
There were two versions of the three tone wrap around w/ the the bottom being a ghost grey. Heck, add some drop tanks from the GP Phantom and drop them on a high speed pass. This way I can loose all respect from the pattern community
The rudder is now done minus the 1/4" dowel for the pull-pull system. The tank floor is ready to go in after adding blind nuts for the gear. There is plenty of room for the tank compaired to my H9 Phoenix 7. I may slide the tank floor up a bit to eliminate the little bend in the gear.
ID:	1835420   Click image for larger version
