will pcm fix my problem?
i have a all metal q60 with a os91 cspec, tj govemer, 502 gyro, 9252 servos, 2000mah nimh batt, rd8000 with fm rx. i have had really bad glitching problems form the get go it was so bad i could not even fly it.
i went threw and made sure everthing was tight check all bearing put some ferites and the servo wires grounded the metal frame move the ant as far from the frame as possible changed the crystals. i did everthing i could think of. i have had three raptors before this and not one problem with glitches. i have noticed that even just sitting on the bench i am getting small glitches it seems to get better when i take the antana off the tx or touch the tx to thr rx on the bench when i move the tx from the back to the front it gets worse. it is a lot better now but it is still no gone can i use a pcm receiver now and not have to worry about lock out or what can i do to fix this.
