RE: Fireproofing the fuselage?
A piece of covering is a great idea. A more expensive but less complicated way is to just use a bottle of thick or medium CA and just "paint' the entire firewall area with it using a small paint brush . More than one coat is good idea if you use medium CA. Multiple coats of thin CA will also work, but it dries so quickly you're more likely to glue fingers together with it.
