ORIGINAL: michsmit
Hey guys,
I just got a new S30 volcano nitro rc truck and it will not stay running. when I plug the exhaust and try priming, nothing happens but yet when i remove the fuel line from the exhaust and blow thru the fuel llne the fuel starts to move towards the carb. Would this be due to an air leak some where? Also can someone pleae provide me with the factory settings or settings for the HSN and LSN, so I can atleast get the truck running. I am going to check for air leaks, Thanks...
Mike
So the fact your saying it won't stay running means it will in fact start...correct? If this is true it sounds like the tuning is affecting the priming and idling. LSN if to lean will make it hard to prime and run at idle. Check your needles. Sometimes the easiest thing to do is just run them back to break in and retune from there.
