RCU Forums - View Single Post - Fireproofing the fuselage?
Old 01-02-2013 | 06:51 AM
wcmorrison
Default RE: Fireproofing the fuselage?
Mix up your epoxy in a 2 ounce cup and then add about the same amount of alcohol as used in the epoxy. That thins it out. The alcohol evaporates but allows the mix to spread very easily and makes a thin surface coat. BTW it is fuel proofing, not fire proofing. Works for me.</p>
