RCU Forums - View Single Post - 95 AX run in problems.
Old 01-02-2013 | 07:18 AM
Bax
Default RE: 95 AX run in problems.
Your symptom is that of a too-lean engine. Very likely, your exhaust system does not provide enough pressure to the fuel system to give you good fuel flow. As a result, the engine gradually overheats and then quits. You may need to reduce the exhaust outlet area of the muffler to increase the pressure sent to the fuel tank.
