RE: Fireproofing the fuselage?
After putting the epoxy on the firewall and cowl (if it is wood) I cover the model. Then a run a little bit of ca around the edge where the covering meets the epoxy. This keeps any oil from seeping under the monocote/ultracoat.
I also paint the firewall before putting the epoxy on. It gives a more finished look than just clear coated wood.<br type="_moz" />
