ORIGINAL: michsmit
Wow that really worked. Thank you so much. When it started my wheels where turning a bit does that mean my idel is set too high? Also I pinched the fuel line going to the carb to stop the engine until I can break it in. It is getting late here and its -24 outside, do you think it will be ok to run the break-n in a couple days when it warms up?
Thanks again you made my day!!!!!!!
Mike.
Personally I wouldn't run it with temps that cold. Your not going to get a good break in. When it's that cold its going to run very lean to begin with. For me, running nitro below 40 degrees is hard on the engine. It can be done, but make sure you're rich enough. With it being that cold out you're going to want a temp gauge for sure. Remember when breaking in you want the engine to heat up enough for the sleave to expand without running too hot. As far as the wheels turning, when it's idling on the block they will likely spin a little. If you hold it on the floor and it's not trying to pull or roll away your idle is fine. Tuning isn't always perfect, some carbs are hard to get dialed in where there is absolutely no roll at idle. Your HSN will also affect your idle so for now get it broken in and then you can really dial in the tuning.
