RCU Forums - View Single Post - Done with GP epoxy!!!
Old 01-02-2013 | 07:26 PM
invertmast's Avatar
invertmast
My Feedback: (23)
Default RE: Done with GP epoxy!!!
GP glues and Epoxies suck, so does the Mercury adhesive Kicker spray nozzles and there epoxies (I'm pretty sure the mercury epoxy and GP epoxy is from the same bulk manufacturer, as they both crystalize and harden very quickly no matter what temperature they are stored at).
I use ZAP epoxies exclusively as it is the only brand that I have found that routinely sets up Rock hard even with a small inconsistency in exact quantities of hardener and resin. They can sit in 80+ or 60- degree temperatures and the only that that changes is the viscosity will either thin slight or thicken slightly, never once have I had any crystallization issues. They aren't much much expensive either (maybe $1 or 2 per kit).
The mercury adhesive CA kicker spray nozzle's suck as well. I don't know what there problem is, but over the past 2 years, I have gone through over FIFTY! (Yes 50!) of there spray nozzles. They sent me a box with at least 2 dozen spray nozzles, and the LHS got a box with 3 or 4 dozen nozzle's as well. I used all of them up in less than a year. Most lasted less than 1 hour of "building" some didn't even last more than 1 squirt before they would start leaking under the pump cap or the atomizer nozzle would pop out of the cap. COMPLETE CRAP!
Now I ONLY used ZAP "zip kicker" spray bottles and pumps. 2 years later and 10 large kicker refill bottles later , I am still using the same Original spray pump nozzle on the kicker bottle.
The mercury adhesive CA is Ok, I prefer zap as its more consistent in consistency, strength and cure times, but their lack of a re-useable bottle and a refill bottle keeps me from using them. Mercury has a nice 8oz refill bottle that lasts a few months.
