ORIGINAL: psmith36
Thanks for the comments I will keep them in mind. I have heard of the problems with the tail being heavy so maybe I will go slightly larger.
Yes the tail is heavy and it also lacks some authority. You can solve part of the problems by adding width to rudder and elevators, you don't have to add the balance tabs like I did and then drill the heck out of it to lighten it up and you probably won't even add any weight.
