RCU Forums - View Single Post - Illusion Build
Old 01-04-2013 | 05:11 PM
  #42
edp's Avatar
edp
Default RE: Illusion Build
I had a minor problem as the cores were cut askew. I trued up both the root and tip. I then added 3/32" to fit it to the print. It took longer for the glue to dry than fixing it. I cut out for solid elevators. I didn't have much to glue my hinge points to. The stab is ready for joining and the anhedral sanded in at the root roughly 2 degrees per side. This gave me the 2" called for at the tip.
The wing are also sheeted. I have added some Cf horse hair to the TE hoping to help w/ the dings[:@]
ID:	1836800   Click image for larger version
ID:	1836801   Click image for larger version
ID:	1836802   Click image for larger version
ID:	1836803   Click image for larger version
