ORIGINAL: Checklst
Sorry to bother you guys but for some reason I can't seem to get flaps to operate on a 120 lite with my 9303 converted to Spektrum 2.4. I have AR7910 DCMX receiver. I have the(2) ailerons servos working fine one servo coupled to AUX 2 working fine My rudder and elevator are single servos working so I still have AUX 1 and Gear channel left........I just can't seem to to assign Aux1 or gear to the flap switch, to use the flaps on the 120 lite.
I started on a fresh plane channel on the 120 lite because I knew with the seven channel receiver I knew would loose crow and some of the flap to elevator mixes......I did not use most of these mixes anyway. My manual is not me helping much.
Most searches I have done are using 8 and 9 channel using Aux 3&4 tying them to flap switch..............This AuX 1 seems to the most problematic in the screens the Aux 1 not listed as a choice in the menu screens I am usually in.
I am so use to doing this with 9 channel receivers and downloaded instruction from you guys.........I feel stupid as to why this 7 channel is frustrating me so.
When you are setting up Dual Ailerons and Dual Flaps you need to go into Wingtype, choose Normal, and scroll to the Mate row and select the channels you want to Mate with Aileron and Flaps (I assume you have separate control surfaces for Ailerons and Flaps and you are not using Flapperons). You would use the same procedure for Dual Elevators. You don't use the Programmable Mixers to get Dual Ailerons, Elevators, and Flaps, however, you can use the PM's for other purposes. If you need to Inhibit any channels you intend to Mate, you would do that in Device Select. This includes inhibiting Switches that were formerly assigned to the Mated channels.
