ORIGINAL: TPL33
ORIGINAL: JohnBuckner
As you noted the connections on all such fill valves are inserted in the clunk line from the tank to the carburator or the main remote needle valve.
Overflow is the same as every simple two line system and will come out of the vent line from the tank Which is plugged into the muffler which is normally unplugged at the muffler to watch for a full tank.
My personal reccomendation is to avoid any third line as it is actually redundant and unnesesary. Also I would even avoid even the refueling valve altogether as they will at some point get dirt into the valve and cause running problems that will cause much headache. Its far better to use a simple two line system system and it even works well in cowled engines when done right plus it provides an exposed loop for you to use when learning the pinch tuning technique.
John
The engine and fuel lines for this aircraft will be completely within a cowl, so, short of having to take the cowl off each time I refuel, I don't see any other option than the Remote Fuel Valve. The muffler will exit from underneath the cowl, so, from what you're saying, I'll have to unhook the fuel line from the muffler for the overflow as I do now for my uncowled engine? Thanks for the help guy's.
Also, if I don't use a Remote Fuel valve, how are the fuel lines set up for refueling without having to remove the cowl? Do you run the line out and then back into the cowl with a in line fitting that's removed for fueling? Run the lines out the bottom of the cowl? I've never had a cowled engine so I'm new to this. Suggestions welcome!
