ORIGINAL: William Robison
AAC is a variant on ABC, substituting aluminum for the brass sleeve. Same characteristics as ABC.
ABN is a cheap variation on ABC, instead of using a chrome plating it has nickel plating on the sleeve. Thunder Tiger has given excellent service with ABN, and their selling price is low, probably in a large part because of the inexpensive ABN process. OS. the other current user of ABN, has a continuing problem with failure of the plating which effectively ruins the engine due to the excessive price of repair parts. Side note: The OS engines with ringed pistons are still of good quality and long engine life. ABN is cheap to make, and is easily damaged.
Does that mean my O.S. LA engines are junk prone to fast wearout? I should try to buy FX or AX in the future?
Who makes the AAC engines?
