ORIGINAL: Deandome Is the Eclipse 7 2.4mhz always/only the 'Pro' model, or did they have a 2/4 version of the older model?
Looking at the 0008 cable, it's the same as the 0005 save for it has a battery connector vs a battery, so I don't think that'll make a difference
I tried to digest your thread/instructions but it mostly talks about getting the right cables and if & when you turn the power on the Tx when you plug stuff in. I tried every option w/that already w/the 0005, so I'm wondering if there are any other 'settings' I need to adjust in the menus or switches? Because whenever I plug in the stereo jack, I see "Master" or "Slave", depending on whether the power is on when you plug it in....do you get that when you're running a simulator?
Again, when I hook everything up w/the Tx power off, the LCD on the Tx fires up fine, and the LED on the AnyLink goes on....it's just the plane that sits there doing nothing.
"Again, when I hook everything up w/the Tx power off, the LCD on the Tx fires up fine, and the LED on the AnyLink goes on..
..it's just the plane that sits there doing nothing."
-Indicates link between the Eclipse 7 Pro & AnyLink unit is set but the receiver has not been linked.
refer "Bind to your Tactic Rx". page 7 AnyLink manual V2, attached previous post #4
Also as in post #4, Please contact your Anylink service centre for further infomation or service.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
O&O.
