RCU Forums - View Single Post - Oil leaking all over the inside cowling
Old 01-06-2013 | 06:51 PM
bjr_93tz
Default RE: Oil leaking all over the inside cowling
The little graphite gasket the goes between the flange that screws into the head and the header is still there and in good condition?
I have seen what you describe and boy did his plane look a mess, a new o-ring fixed it up but if the new bits are too loose then??
I have also seen the spark plug washer a bit offset and not seal properly, but the residue wasn't black, it was a bit clearer.
