RCU Forums - View Single Post - CMP 120 Zero ARF Build thread
Old 01-06-2013 | 11:04 PM
  #1360
frets24's Avatar
frets24
My Feedback: (15)
Default RE: CMP 120 Zero ARF Build thread
Per your request 77CH, and as promised above.
I made up the proofs to cover just about everything as there were some minor differences between Imperial Japanese Army and Navy as well as early or late models. I like the research and figure if I'm going to do it, I might as well do it as well as I can
The little 3 character "no step here" figures were usually always along the back of the wing over the flaps and had, more often than not, been walked on so much that they were well worn...is that irony?
The same figure some times appeared on gun and ammo access covers in both the vertical and horizontal orientation so I included a selection of sizes and orientations to fit all needs.
As far as the covers there seems to be no rhyme or reason to what's marked and what isn't...the same cover between right and left may only be marked on one side and a different cover on the other. In other words there are four panels on each wing for a total of 8...there may be 7 of them marked on one plane, three on another, and only two(both on the same wing) on another. Some had none. There's enough figures to do all 8...your choice whether to make it random.
Circles and dashes I plan to paint and if anyone decides to get dry transfers I'm sure they can do a page of circles and dashes and send off the proof/draft or copy them on to waterslide paper themselves They're on the placement chart, just not on the proof sheets.
The proof sheets are 8.5x11 and should download in 1:6 scale. The placement charts will expand in the quickview online and download to accomodate a 14x20" fullsize print
ID:	1837700   Click image for larger version
ID:	1837701   Click image for larger version
