RCU Forums - View Single Post - Engine fires with choke closed?
Old 01-07-2013 | 09:09 AM
ameyam
Default RE: Engine fires with choke closed?
I have a filter as part of the fuel suction on the line pump. but the pump is not dedicated to gas, so some dirt probably got on it when i was transfering from glow duty then. There is still some time before I put together the dedicated gasser. today's test was simply to check that the ignition works & I will take the test bed Extra 60-90 convert to field just one day to ensure that the ignition step (due to which 8 changed the stock dle #4 ignition) is now eliminated. Hopefully by then the filter problim is sorted
Ameyam
