RCU Forums - View Single Post - help with idle problem on 91AC
Old 01-07-2013 | 01:02 PM
Dave Harmon
Default RE: help with idle problem on 91AC
These engines will idle and run great if adjusted properly.
I suggest that you put it on a test stand and get it adjusted so it idles correctly....then put it back on the plane and it should idle about the same.
