ORIGINAL: superflisi
HI
I have a YS 91 FZ that I am having some problems with. The motor has a about 4 gallons of fuel through it, but will just not run at low throttle without quitting.
As the instructions I have set the high speed needle, and after much fiddling cannot get the low end to run reliably.
I have noticed that after reducing the throttle from full to idle, the engine ticks over for a few seconds then picks up rpm and quits.
Can anyone tell me if it is normal for there to be a lot of air bubbles in the tube that goes from the regulator to the carb ( at low throttle ).
I have read other threads about this type of engine, and although I am very familiar wth standard four storke engines this thing has me puzzeled,
Hope someone can help
Simon
Sounds like the low end is lean
Try setting up the mixture as describe on this page
http://www.probuild-uk.co.uk/factsheets/ys_engines.php
Hope this helps
Dirk
