RCU Forums - View Single Post - AMR 33% Waco YMF-5 Build
Thread
01-08-2013, 01:53 PM
2381
WacoNut
RE: AMR 33% Waco YMF-5 Build
The fiberglass hood has been installed.
The fit is good, the hood does need some repair work to fix a few fractures from the crash as well as the nose ring.
I decided I am going to go ahead and inistall the front instrument panel and remove the former in the middle of the cockpit. I may leave the crossmember in place that the former is sitting on. For the most part it will be out of sight. If I put a cover over the front cockpit I would still have to remove most of the former to keep the cover from contacting it when it is stretched over the cockpit opening.
I need to make some clearance for the center section wires and get them installed and work on covering the fromt wire with wood. Alot of little odds and ends need wrapped up before covering and paint.
Later!!
Anthony
Reply
Like
WacoNut
View Public Profile
Send a private message to WacoNut
Find More Posts by WacoNut
View iTrader Profile
