RE: 'TO USE' or 'NOT TO USE' a Support Strap/Bracket on a Wrap Around Pitts Muffler?
I've seen this problem solved by using a better standoff system where long standoffs are needed, as opposed to using the popular aluminum ones. Like using hardwood square stock, boxed in on a couple sides, for example. I've seen others, with very good stand off boxes, still have the issue. If you know the muffler to have the issue, strap it.
