RCU Forums - View Single Post - Plastic Magic
Old 01-11-2013 | 10:59 PM
Panther F's Avatar
Panther F
Default RE: Plastic Magic
I've been using Ambroid Pro Weld for some time. The thing with this type of adhesive is that you're not really gluing the parts together, like in the past with plastic glue you would attach glue to one part and place the other part on the glue.
With this, basically you place the two parts together and then let the cement seep into the joint where the two parts meet creating a bond. This is so much faster and much neater a way of building a kit.
Now there are some areas or applications that require practicing restraint of how much is applied OR by using CA instead of the cement, just because the part(s) are too small.
And, with this type of cement, drying time is a thing of the past... waiting for parts to dry.
This way it's immediately ready for the next step.
~ Jeff
