RE: RC Surfer
Hey Kite.......good looking prop....that size looks great for your set up. It also looks more like a submersible prop rather than a surface drive prop which will reduce tail lift.
Are you running a M4 threaded end shaft ? I have been looking for 30mm submersible CF props, without much success. .....any help would be great.
My board is coming along..........If it was a regular surfboard I would be planning my first surf session...........BUT - being an rc board.......the work has only just started.
Got the first 'hot coat' on .......now to cut out the housing and fit all the running gear.....then the fiinal 'hot coat'..........and some wonder why they cost more than a Surf Board...LOL
With the 80mm thick foam I am able to create a healthy nose rocker.....which works well in the tighter sections.
Great weekend ALL !!!
Bro ********. ...
Share the STOKE !
