RCU Forums - View Single Post - Servos
Thread: Servos
Old 01-12-2013 | 03:03 PM
huck1199's Avatar
huck1199
Default RE: Servos
I think you want to know if you should mount the servos with the output shafts near or far relative to the ailerons. Is this correct? I mount them closer to reduce control rod length. The horns should be mounted as close to perpendicular as possible - and both should be match for position so that if you use a "y" harness they will operated properly..
