RCU Forums - View Single Post - NSRCA/AMA EXPO
Old 01-13-2013 | 10:29 AM
shannah
Default RE: NSRCA/AMA EXPO
Steve Neu is also adding a line of props. He has some RASA style folding prop designs that he is going to offer. Nice looking workmanship.
The large inrunner design is very interesting. It looks about the same size as the Pletty Advance. He didn't have any detailed specs on it but said it was similar in performance to the F3A-1 inrunner. The production model will be similar to the one at the show but will probably have more material around the front framework. It can be rear mounted or firewall mounted.
He also has the helical gear version of the P42 gearbox that is used on the F3A-1. It should be much quieter than the older gearbox.
I really liked the new charger he had. It can charge two 10s packs simultaneously, has the ability to charge at high C rates, has a neat user interface, can discharge packs, and looks to be well made. I just might have to find a way to get that one into my field box this year.....
