RCU Forums - View Single Post - pull pull system
Old 09-14-2003 | 07:36 PM
Stick Jammer
Default RE: pull pull system
Pull-Pull has two purposes. The most obvious is the fact that it does not need to rely on pushing the control surface thereby eliminating the chance of a pushrod bending under a flight load. The second reason could be merely servo location to arrive at the desired CG without having to add ballast.
