ORIGINAL: warbirdfanatic
Hi Guys
Does anyone have a good list of EDF birds that are 1600mm or wider wingspan? I'm just thinking about converting an EDF kit for pure laziness, Hobbyking do a large F86 which looks like it would be good enough to convert or even make a mould from to put a 15lbs turbine in!
Or, if anyone has any links to free EDF plans or turbine plans that would also be handy!!!!
If its a 15lber you intend to use..most of the planes already mentioned are only good for a P20 or Wren44.
Sounds like you want to use a P-60
This is what Im doing after my Byron F-16.
SU 37 from the King. They dont sell them anymore but that might be found at the manufactuors website. Prodesign.
Im placing a P-60 between the engines. Fuel tanks will most likly be installed in the intakes.
Specs:
Wingspan: 1200mm
Length: 1737mm
about 15lbs flying weight.
