RE: WACO YMF
Hello Albert, You've done some BEAUTIFUL work! I see on your landing gear profile you may have done what some kit makers have done... that the rear edge should end up behind the wing leading edge. That makes the whole triangle shape different. If you're not after 100% scale accuracy it'll be fine and much easier from an engineering standpoint.
I love the build. Mitch
