You know the expression, "can't see the forest for the trees"?
Sometimes the simplest answer is just a blank.
Thanks again for everyone's input, and especially Andrew. Simply rotating the servo arm 180° did the trick.
Again, this is just a trial run and not the final gear that will be used but it gives me some info I need.
