RE: A beginners guide to jets, revised
Albert, Jeremy and All,
Great input here although some may feel thatthe requirements are much too detailed.
However, one requirement is necessary for any applicant to the AMA Turbine Waiver process. This is "All turbine waiver applicants should have accomplished at least 50 flights on a high performance model. Fixed wing models should be capable of sustained speeds of 100 mph or higher." Ref: Safety Regulations of Model Aircraft powered by Gas Turbines. Some turbine waivered CD's may ask for a log book as a record of the 50 high performance flights before administering the turbine qualification test.
Also, few of the models mentioned for training are actually capable of 100 mph sustained flight.While both the Habu I and II are good practise models they are only good for 80-85 mph. The Habu 32 exceeds 100 mph but at a higher cost level. I recommend the many prop jets that are available and easily meet the 100 mph requirement, such as the Patriot, F-20 Tigershark and Jackal- all readily available and some with a retract option.Some warbirds are also applicable to meet this requirement and provide good experience with a high wing loading, flapsand retracts if fitted.
I'd like some wording to include these models and the 100 mph speed requirement in final versions.
Art ARRO, AMA Turbine Waivered CD
