RCU Forums - View Single Post - OPS 60 Goldhead instructions and advice
Old 01-15-2013 | 06:59 AM
doxilia's Avatar
doxilia
Default RE: OPS 60 Goldhead instructions and advice
Neville,
Did you tach the engine at low? What plug are you using? Fuel (brand, oil)?
Does the engine shut down when the needle is closed? Does it transition smoothly? I don't see a pressure line, do you have one going to the header or pipe?
I'd suggest taking the prop down to an 11x7 to 11x8 for a starters if the engine is newish and bring the rpm up by tuning the exhaust. You ought to be able to get it in the 14K+ rpm on an 11x7 when tuned.
I'm going to look for my instructions.
David
PS Nice Arrow by the way! MK kit?
