RCU Forums - View Single Post - OPS 60 Goldhead instructions and advice
Old 01-15-2013 | 07:50 AM
TFF
Default RE: OPS 60 Goldhead instructions and advice
What kind of setup do you have? It does not look like you are using muffler pressure. Most guys used a pump with these engines to keep the fuel flowing. With out being able to adjust the needles, the pipe needs to be tuned too. If the engine can not "get on the pipe" the carb will not adjust right. Like above the prop size has to be right.
