RCU Forums - View Single Post - OPS 60 Goldhead instructions and advice
Old 01-15-2013 | 01:30 PM
nevster
Default RE: OPS 60 Goldhead instructions and advice
gents
thanks for all the good advice. I will take off the carby, clean it and inspect the fuel tank.
I was running muffler pressure - just didn't show up on the photos.
I will also try an APC 11x7 prop. The fuel I'm using is 10% cool power.
At idle the motor is doing slightly under 5000 RPM.
David - the model started out as a polyester fuselage which I "inherited" (see attached photo) - can't remember how exactly,
and then I scratch built wings and tailplane from plans off the net. I'm also trying e-flite electric retracts.
I have considered an OPS pump - I don't think I could actually fit it in however - I'm struggling to fit in the battery
and leads for ailerons, flaps, retracts etc etc
I will let everyone know once I've tried a few modifications
Thanks again
