RE: Charging Dual / Parallel LiFe Battery RX packs
I have been using the NoBS setup for some time now, switched over to LiFe packs 2 years? ago and continued using the same setup. I balance charge each pack using a Cellpro charger but only 1 at a time, have never tried to charge both at the same time.
BTW, while saying nothing negative about HK batteries, I have had, and my friends have had, issues with less expensive battery packs so now I buy only SR or NoBS packs. Don't listen to opinions, do the experiment yourself, buy one of each and dissassemble and check the quality of the construction, welds, wires, connectors etc.
Whit
